Hi all.
I built a spec with the following branch table:
(consider one variant of resizing - from 2" to 1/2").
I have 4 options:
1. Tee reducing SW
2. Tee reducing THRD
3. Sockolet
4. Pipe (Stub-In)
By default I got Tee reducing.
But I want to change the connection option (click on blue triangle). And... I not see sockolet and stub-in
If I change priority (for example, for Sockolet = 1), I see ONLY sockolets:
But I want to see all possible connection options: Tee SW, Tee THRD, Sockolet and Pipe.
How can i do this?
Dear @DmitryKhot,
Click on More sizes (x1/2")
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear @DmitryKhot,
if you have inserted a Tee, only the Tee is displayed using the Substitute function.
This has nothing to do with the branch table.
I think the function you would like is not in Plant 3D
Hartmut Eger
Senior Engineer
XING | LinkedIn
I understand that these questions are not for you, but ... 🙂
1. Why is this option available, for example, if I want to change an Elbow
You can see 3 options for Elbow - LR, 3R, SR
2. What is the meaning of the Branch table and setting priorities for selecting options, if they are still not available...
Dear @DmitryKhot,
please make a poste on the IdeaStation.
This part in the program code does not exist.
Hartmut Eger
Senior Engineer
XING | LinkedIn
This is because we are talking about two different functions - Branch table and part substitution.
The branch table refers to what connections can be made. They do not necessarily define what parts can be interchanged or substituted with respect only to size of that given class.
Part insertion and substitution is reliant on class definitions. So an OLET is not a TEE and visa-versa.
A good point here is that a bend and Elbow fit under the same class or subclass and also are not impacted by branch tables. Same will hold true for valves etc.
I do agree that this is a good idea for the IdeaStation as @h_eger pointed out.
Dear EGAR sir,
as per this post dated in 2017 any update from this case ??
i have same issues with branch connection in my case i want 100x40 branch connection pipe to pipe and reducing tee option in same way is there any update from recent 2023 version
NO
Hartmut Eger
Senior Engineer
XING | LinkedIn
