AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
BOM not showing descriptions
1 REPLY 1
wstowe
329 Views, 1 Reply
I received a model from another company to drop ISOs from and produce Spools from the PDF files.
The problem is that non of the BOM description items show on the BOM. FYI...a few pieces of pipe i had to replace with Imperial Place holder spec pipe and those showed on the BOM just not anything that came from the other company.
However, when I loaded and dropped an ISO using the default project as a template it dropped the ISO fine(except the border and such not being what I want) and all descriptions showed fine.
I don't want to use the Default project as a template because I will have to fix a lot of things for it to come out the way I want. Hoping there is a simple setting to allow the descriptions to show on our normal company settings.
Thanks for your time!
1 REPLY 1
h_eger
in reply to: wstowe
Dear @wstowe ,
I think an admin training on ISO generation and title block configuration should solve your problem
Since your project is probably about several problems and we do not have this project available, I (IMHO) unfortunately cannot help.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
