Bolt & Nut Washer
Bolt & Nut Washer
PHAN.TUAN.TRI
Bolt & Nut Washer
PHAN.TUAN.TRI
Hallo,
1) I had a case at work. How can I add washer to the bolt nut gasket set ?
2) If in my spec there are 2 types of bolt nut with different material. So how can I choose the type of bolt nut I want?
If you have any idea please share with me.
Thanks you and best regards,
Phan Tuan Tri
h_eger
Dear @PHAN.TUAN.TRI ,
this link should solve your problem
https://blogs.autodesk.com/in-the-pipes/2016/07/16/autocad-plant-3d-handling-bolts-in-piping-specs/
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
PHAN.TUAN.TRI
And how about add washer to bolt & nut gasket set sir ? It's question number 1.
h_eger
Bolt Set and Gaskets are in the Fastener class and are automatically added when connected.
If these are available in the pipe spec.
Hartmut Eger
Senior Engineer
XING | LinkedIn
PHAN.TUAN.TRI
Sr. Sir. You misunderstand.
I mention about Washer. I attach a picture.
And I want ask you How can we add washer to model 3D ? Bolt, Nut, Gasket easily to add. But I don't know how to add washer.
Mention washerMention washer
Tomislav.Golubovic
You put them in the description. Plant3D doesn't draw the bolts (as such) so its a bolt 'marker' in the model. So the description might be something like M20 bolts c/w 2 nuts and washers or whatever it is you're going to buy
PHAN.TUAN.TRI
That good idea sir. Thanks you very much.
