We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Bill of Material Control
Srisurya
Message 1 of 13
Srisurya
Dear Experts,
I wanted to show a fitting in model but In report it should not give any quantity??
Can we show something like dotted ??
SriSurya Rao Lankapalli
Replies (12)
Message 2 of 13
TomislavGolubovic
In the properties mark it as Existing?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 3 of 13
Srisurya
Thats really great reply.
Its also split the pipe in Isometric??Cant we make it dotted ??
By the way may I know difference between Demolition/New/an empty row??
Because these 3 are giving same results.
Message 4 of 13
TomislavGolubovic
If its marked as Existing in the model it will make it dashed on the Isometric and it won't be counted.
Tomislav Golubovic
Autodesk, Inc.
Message 5 of 13
Srisurya
This is im taken as example with 500 spool on each side still its giving a splitting  in 2 sheets
undefinedundefined
Message 6 of 13
TomislavGolubovic
Is it the same line number? If you want to split then you'll need to put a manual break in it or change the split properties
Tomislav Golubovic
Autodesk, Inc.
Message 7 of 13
Srisurya
Yes,
Its a same line number.
I have not put manual break points
Message 8 of 13
TomislavGolubovic
Pic of the ISO's?
Tomislav Golubovic
Autodesk, Inc.
Message 9 of 13
Srisurya
Here are attached along with model....
Message 10 of 13
TomislavGolubovic
Mine works fine, I am using the OOTB Isometric Styles
Tomislav Golubovic
Autodesk, Inc.
Message 11 of 13
Srisurya
Thanking you
By the way What is OOTB Isometric Styles??
Message 12 of 13
TomislavGolubovic
OOTB = Out Of The Box
Tomislav Golubovic
Autodesk, Inc.
Message 13 of 13
Srisurya
This work I came to know through goole but
how this can be used in P3D??
