Hello.
I working on a big project and we haw done hole packet from PID to ISO. The project now contain app 24 PID 4 specs 13 3D piping models 1 equipment model and several civil models.
It has not been easy to reach so fare and we haw learned a lot about how to use and not use Plant3D.
We struggle with the different pipe dimensions in BOM list. It will not show total length on each pipe dimension in the different specs when we do the total BOM in report generator. It look like it summarize same spec and show only one dimension. The strange thing is that it is not same for all specs. Some spec are ok. When we does them separately on each pipe system it looks ok. We had a lot of work then with making manual BOM (the old facion way) parallel with the project.
Until now we haw created app 75 Isometric drawings and roughly calculation will be that we will end app on 250 to 500 Isometric drawings, so it's a little bit sad that everything not working.
We did not buy Plant3D to do things like this manually. 😞
Someone haw experience with this out there?
Jon 🙂
