Best way to copy and paste line numbers?
akif.coku
akif.coku
Best way to copy and paste line numbers? Any Lisp routine out there?
DVaquand
Hello
PLANTCOPYLINENUMBER system variable active ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
akif.coku
Yes, that one is known to me and set already. I was hoping on a Match properties way of achieving this but that seem unlikely as per my understanding. The benefit of such a feature would be to avoid loosing valuable time and select errors on line number lists as I see it.
Michiel.Valcke
Have you tried using the Datamanager?
I usually just select all the items I wish to have the same linenumber and use the properties palette to update them all at once.
