How i can draw R125 and R400 correctly on this pict
Solved by Michiel.Valcke. Go to Solution.
The general autocad forum might be a better place for this
https://forums.autodesk.com/t5/autocad-forum/bd-p/706
But one way you can do it is by drawing two circles with the tan, tan, radius option, and use the trim command to clean it up afterwards.
Yeah, its working man for the R400. So very thanksfull. But for the R125 i used "Fillet" command to finish the drawing.
