Hello!
I'm new to AutoCAD Plant 3D and would like to know if there's a way to automate the tagging of equipment. I'm working on a large project with hundreds of pieces of equipment, and doing it manually is very time-consuming and difficult.
Thank you for your help!
where should the values for an automated TAG assignment come from?
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
There is a logic behind the tagging of the equipment. I'm asking if there are tools to implement this logic.
I don't know of any tool that can fulfil such a task.
Hartmut Eger
Senior Engineer
XING | LinkedIn
So, if I have a large project with hundreds of pieces of equipment, I have to manually enter the tag for each one.
I don't know what you have already processed in your project, but if the components already exist in P3D, you can either fill the respective groups with life in the data manager or export the groups and add the values in Excel and update everything after the import should also work.
Hartmut Eger
Senior Engineer
XING | LinkedIn
