AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
AutoCAD Product Design Suite 2014 and Plant3D 2014
2 REPLIES 2
samsonthomas7606
313 Views, 2 Replies
I am using Plant3d for couple of years. After the last update to P3D 2014 everything was fine. Then Product Suite 2014 was installed (needed to use simulation). Since then I am not able to get the Project Setup window in P3D. When i tried to do project setup, Plant freezes. Then escape button helps me to get out. Same thing is happening with Isometric window, I am not able to sellect advanced option. If i sellect advanced option Plant freeze and esc button unfreezes. Anybody else having this issue? Any suggestion is greatly appreciated.
Samson Thomas
2 REPLIES 2
Sounds like the dialog box is off the screen. To move it, when it 'freezes' press the Alt button, then the Space Bar, then the M key, and use the arrows to move the dialog back to the main screen. You'll see the mouse cursor move to a sort of 4 arrowed icon on a particular side of the screen, and from there you can determine where the dialog box is, and using the arrow keys will move it back.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Thanks Tomislav,
Yes my dialog boxes were off screen.
”Boost
