In Plant 3D, is there a way to connect a flange on a pipe quadrant. We have a client that got this kind of connection in his project. We know we can connect a pipe to a pipe quadrant, but we can't get to connect a flange.
We are working with Plant 3D 2019
Product version: M046.1003.r3 Autodesk AutoCAD Plant 3D 2019.1 Update
Built on: P.162.0.0 AutoCAD 2019.1.2
See attached a picture and the file we are trying to get it done.
Thank you
Thank you
In fact I'm realizing that the client is using a long weld neck flange for this connection and there seams to be no long weld neck in catalogues. I suppose I should create a custom part.
If we go with a small segment of pipe stub-in, is there a way to set the segment to not appear in the cut list and bom ?
Could you please point me exactly where are these Flangeolets. I'm trying to find them but looks like I'm not looking at the right place.
thank you
thank you
