AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Auto placed reducer issue.
4 REPLIES 4
abdelaalsabra
158 Views, 4 Replies
Hi All
I have made a new end code as (CT) end connection, and I made a new pipe spec for cable tray by end code connection (CT) the issue when changing the size while routing pipes does not make reducer though the spec contains reducers item.
4 REPLIES 4
does your reducer have the CT endcodes for both ports?
Hi Michiel. Valcke
Yes, all the items in the cable tray  spec have the same end code (CT)
Do the nominal diameter of the reducer ports correspond with the nominal diameter of the ports of the cable trays?
Can you share a screenshot of your ct joint setup? If there are any required matching properties other than ND you'll have to make sure they are consistent between your reducer and the trays as well.
Thank you
there was none matching value at (CT) connection setup.
It works rightly now.
