- Mute
- Permalink
- Report
I have created several custom valves and regulators from STP files provided by the manufacturer. I went through the usual process of making them a block, adding ports and then adding them to my custom catalog. I can auto add a flange to 1 port of each of them but not to the second port of any of them. They all have 2 ports defined & I checked the "All Ports have the same properties" on the Connection Port Properties frame, being a FL End Type and RF Facing. The class is correct. When I click the plus to route pipe I get the error "Cannot connect parts. AutoFlange-" When I attempt to attach a flange to the same end I get this error:
I gather it has something to do with the facing of the port but I set them both to the same. The pressure class is the same for both ports as well.
