Array with python for double component
traiduong014969
traiduong014969
Hi guy,
Recenly, Im trying create a plastic flange. In this have two componet I need make with array feature.
This is number 1 and 2. You can see snapshot below. Howerver, both number 1 and 2 in the same place or  created  unequal angle
Here is piecs of code to make them. Somone can help me fix that.
Thank you !
 phi1=360/N
    FirstAngle1= phi1/2
    InAngle1= FirstAngle1
    phi2=360/N
    FirstAngle2= phi2/4
    InAngle2= FirstAngle2
    No = 0
    while (No<N😞
        number1 =  CYLINDER(s, R=D2/2, H=T, O=0.0).rotateY(90).translate((0,D1/2,0)).rotateX(InAngle1)
        number2 =  CYLINDER(s, R=D2/2, H=T, O=0.0).rotateY(90).translate((0,D1/2,0)).rotateX(InAngle2)
        InAngle= InAngle+ phi
        InAngle2= InAngle2+ phi2
        No= No+1
matt.worland
It looks like your FirstAngle1 = 36, but should be 90 - 36 = 54
Keep playing with the FirstAngles until you get them in the correct start position.
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
traiduong014969
Thank for your answer. I have just test with your formular. Howerver,  it seems the angle dont follow any rules. You can see snapshot that i test with N=3, N=5,  N=6
matt.worland
Your cylinders look correct, change the brace FirstAngle to 90
traiduong014969
I attach file to test. please help me fix that. I trying replace some fomular, but Its not work
matt.worland
The attached should be working.
traiduong014969
Thank you @matt.worland  to spent time to help me. I have just check your code and it worked fine now.
