Annotation ISO font Size
Ahmed1081975
Message 1 of 11
Ahmed1081975
Hi Autodesk Support, Annotation for ISO font Size Is 1.7678 and the other whole annotation are 2.5 how can I make the ISO annotation same the others 2.5 For more clarification refer the attached file. Regards, Ahmed Helal
Replies (10)
Message 2 of 11
VinodBalasubramanian
Autodesk Support
Autodesk Support
Have you tried looking into this article which might help you to set your annotations correctly under isometric style in project settings ,
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Font-Size-of-Line-Numbering-and-cutlist/td-p/3426599
Hope that helps. Do let me know, if the issue is different.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Message 3 of 11
Ahmed1081975
I thing the Autodesk People not understand what we are meant,
 Our Problem When we are using the option in the Isometric Settings to show the Part No. Or Tag No. Or .....,
 As isometric whine generating the Isometric drawing there are no options for Changing Size From 1.7 to 2.5
 Because it’s Already 2.5mm by default, Hope Understand our Problem
Ahmed Helal
Message 4 of 11
Autodesk Support
Autodesk Support
Thanks Ahmed for the details. I do understand your concern of having a setting on the fly in the iso dialog while creating isometrics. I will provide this feedback to our development.
In the meantime, you could use the annotation themes in the project setting to control this before generating your isometric or you could edit the isoconfig.xml file to have a unique font size for all your annotation. Do let me know if you want me to guide you on this with the detailed steps.
I will keep you posted with the feedback from our developers on having an option in the Create iso dialog.
Message 5 of 11
Ahmed1081975
Thanks Very much for your quick Reply,
 Yes please I want your guide by screen shot if possible
Ahmed Helal
Message 6 of 11
Autodesk Support
Autodesk Support
Apologies for the mistake. We just noticed that you are trying to change annotations for sloped lines in the isometrics. I was told that this might be hardcoded with a certain height range for the fonts. I will check with our developers and get back to you on that. Do let me know, if you have any concern.
Message 7 of 11
Autodesk Support
Autodesk Support
Here is another workaround that could help you achieve this.
By setting the text height within the block to 1.4241 rather changing the text style.
Open the IsoSymbolStyles.dwg
Open the Block Editor and select the specific block, eg "AnnoRect".
Select the attribute in the block and edit the text height from 1 to 1.4241.
Set WIPEOUTFRAME = 1
Increase the size of the wipeout so that the attributes are drawn within the frame.
Set WIPEOUTFRAME = 0 and then save and close.
Hope it helps.
Message 8 of 11
emaiolino
Dear, good afternoon.
We need to change the size of text referring to "Line Number" but we do not.
Edit the block mentioned, but had no results.
I could explain how to increase the size of this text?
Ships attached a picture to clarify my query
Thank you very much!
Esteban Maiolino
Titular EMBA Proyectos
Sitio web o nombre del blog
Facebook | Twitter | LinkedIn
Message 9 of 11
dave.wolfe
Please start a new thread. the OP marked this as answered
Dave Wolfe
Isaiah 57:15
Plant 3D Wish list
Piping Labs
Message 10 of 11
emaiolino
Spoiler
Thank you very much, I open a new topic.
Esteban Maiolino
Message 11 of 11
Ahmed1081975
Hi Vinod,
If possible please provide the steps for my issue
Regards
Ahmed Helal
