AnnoSpecbreak text height
DGRL
Advisor Advisor
Message 1 of 25
DGRL
Hi Everyoine,
Well my question is,
After making an complete new house style to use in Plant 3D 2016 we ran into a small challenge.
The text height of the AnnoSpecBreaker is set to 1 in the text style editor ( done the way autodesk recommend you to do )
I changed it into 2 or 3 or any other height you can imaging.
For some strange reason the text height is forced to be 2.121320343559843 and we don't know where this is coming from.
The isoconfig.xml does not seems to be the file to alter these settings as they are removed in the 2016 version.
Back in to 2010 the isoconfig file was used for this as far as I remember correctly.
Can anybody point me to the correct file to alter the text height of this iso symbol?
Thanks in advance
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Replies (24)
Message 21 of 25
DGRL
Hi @dave.wolfe @h_eger @Autodesk
I just found out where the issue lies with the wrong scaling of the iso symbols
The annospecbreaker is behaving really weird and I know where to change it
I only need help from Autodesk on some names.
For the annospecbreaker go to line ,
<PropertyBreakerScheme Name="SpecBreaker" AnnotationStyle="SpecBreak" Tag="Left Right" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="SpecBreakItems" Field="PIPING-SPEC" DefaultAnnotationStyle="Standard" DefaultLeaderStyle="Always" WordWrapLimit="10" EnableMultiple="true" />
<PropertyBreakerScheme Name="InsulationLimit" AnnotationStyle="SpecBreak" Tag="Left Right" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="SpecBreakItems" Field="HasInsulation" DefaultAnnotationStyle="Standard" DefaultLeaderStyle="Always" WordWrapLimit="10" EnableMultiple="true" />
Field="HasInsulation" Is scaling perfect and the text height is also precise I.e 1.8 / 2.5 or 3.5
Field="PIPING-SPEC" does not scale at all.
The last one has issues regarding the text height and scale factor.
Also what I see is that the blockname in the iso is for,
HasInsulation --> annospecbreak
PIPING-SPEC --> AnnoSpecBreaker-1-Iso2DSkew90 or AnnoSpecBreaker-2-Iso2DSkew90 depending on how much you use.
PLEASE AUTODESK
I did already a lot of research on this and please let US FIX this once and forever.
You keep telling that without us you don't have anything to make better but now we did a lot of work for you and we are asking you now to FINISH it
Hope to hear from you
And if you need any more info PLEASE let me know
Kind Regard
Kind Regards
Message 22 of 25
DGRL
Update,
I was reading the isoconfig file and I noticed that the blockname for the annoscpecbreaker is used multiple times.
isn't this the reason why this block is not working correctly?
Search for PIPING-SPEC and see yourself
Again
Look at this line
You can clearly see that Field="PIPING-SPEC" and PIPING-SPEC is found multiple times while Field="HasInsulation" is only found ONCE
Coincident? I don't think so
CAN SOMEONE PLEASE HELP
Looks like Autodesk just don't care enough about there paying customers
Kind Regards
Message 23 of 25
DGRL
Nobody who wants to help?
Kind Regards
Message 24 of 25
h_eger
Hi @DGRL,
all the answers are given. No further answers possible.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 25 of 25
DGRL
Hi @h_eger and @dave.wolfe
It took me a while but I seriously fixed this
In the end Autodesk did not finished there job
I tweaked 2 blocks in the IsoSymbolStyles.dwg and now it is working perfectly
Just finish what auto desk should finish to begin with and your good to go
I will mark this as accepted
For everyone who helped me Thanks for your time and afford 🙂
I really appreciate this
Kind Regards
