All tee's size and spec missing in every drowing in a project
I got a problem today.When I open the project I found all tee's size and spec missing in every drawing in a certain project. While other project (both in same drive of the company server) didn't got this problem.And I think I did not do anything unusual work on my project yesterday.
Does anyone know what's going on?
**I am using P3D 2016,SQL Server.
h_eger
Hi @Anonymous,
it only affects the tees?
Was it changed at the spec?
What does the tee indicate on the Substitut Grip?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
reply the questions:
1. yes, only tee.
2. it didn't. I can delete the tee that missing info and drawing a new one use the original spec.
3. is the pic below what you asking?
Supply other information:
1. When I route pipe using the tee that missing info, this msg will occur
2.I confirm one thing: if I execute this file  "PnPLocalDataCachePurger.exe" will cause this happen. And I think someone might did it before the problem happen He say he did this because he want to solve a problem (see this article https://forums.autodesk.com/t5/autocad-plant-3d-forum/line-number-drop-down/m-p/4888094/highlight/tr...).
h_eger
Hi @Anonymous,
https://knowledge.autodesk.com/support/autocad-plant-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
The error message "PnPCompletionStatus.RowNotFound" indicates that an error occurs in the database with the assignment of the data because a row does not exist.
Did you change something in the project configuration?
In recent times, have there been more crashes in Plant 3D?
Were there problems with the access to the SQL server lately?
Hartmut Eger
Senior Engineer
XING | LinkedIn
REPLAY QUESTION:
1 The project ( SQLite,I converted it to SQL server using "PnPProjectMaintenance.exe",including entire project folder,spec,drawing)is from business owner(Japanese),they did change project configuration.And, the project is P3D 2015 version,I had migration it to 2016 version.
2.No (There is 3 people using P3D,none of them think so)
3.No
The link you supply we saw it before,and it not work at all.
Right now we are testing if the following situation have relation ship with my problem:
1.In SQL Server,there is a strange data that doesn't exist in other P3D 2016 project which made by ourselevs (as mention above,project is supply by business owner)
See the latest column,it's Japanese language,means "size"
This column exist at the very first time I converted project from SQLite to SQL server
2.When we install the P3D program,my version is 2016.sp2,but I still get upgrade info about sp2
Finally we solve the problem.
On tee,our business owner build a custom property and name it in Japanese language.Somehow SQL server can't recognize this property ,then make some of the tee's data didn't transmit between pc and SQL server ,instead restored on pc's cache.
(Our SQL server is under Tranditional Chinese environment)
That's why "PnPProjectMaintenance.exe" only make things worse.
The solution is very easy, delete the Japanese language property,then tee's size and spec data comes back immediately after I press "ok".
