Adding SKEY to custom fittings
MONTECINOS
MONTECINOS
Good afternoon,
I´m going to add a custom flange that i made to my catalogue, the issue is i don´t know which one of the SKEY symbol list do i have to add.
My flange is "Flange Adaptor Spigot Long Grooved for the use of flat-gaskets", similar to the shape of a welding Neck Flange, but is made of Polyethylene, so i can´t to add that SKEY.
Which one would be the best SKEY symbol for adding to this custom flange adaptor?.
I attach 2 image, one of them is the custom fitting that i want to add to catalogue, the another image is the SKEY list symbols available
h_eger
If I see this correctly, the Accessories Flange Connection PE (V-Bund) is added to this component, or?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
MONTECINOS
Good morning,
The "Flange adaptor spigot long grooved" is connected by using 2 flat flanges.
I attach 2 images where is better explained
MONTECINOS
It is an Stub-End connection
h_eger
Flange adaptor spigot long grooved = ISO-Symboltype: LAPJOINT-STUBEND
        ISO-Symbol SKEY: FLSE
flat flanges= ISO-Symboltype: FLANGE
                       ISO-Symbol SKEY: FLLB
Hartmut Eger
Senior Engineer
XING | LinkedIn
MONTECINOS
Hi Betreff,
Thanks for your help.
I have another doubt, ¿Is there any way to add the "Flange adaptor spigot long grooved " to the spec editor catalogue?. At the moment of creating a new componen in  spec editor, in the dropdown list of elements to create as for example FITTINGS, MISCELLANEOUS, etc..., do not appear the option of STUB-END, so i can´t create it as custom element.
I would like to add it to my custom catalogue and try to configure the programm. I want at the moment of adding a flange to a pipe that "Flange adaptor spigot long grooved" appears automatically after placed the flange as in images that i attached before.
I don´t know if there is a way to configure that behaviour .
