Adding custom - AutoCAD DWG block to spec editor
fahmi_audishNMWLM
Message 1 of 14
fahmi_audishNMWLM
I am currently working on adding Pressure Transmitters to the spec using "Custom - AutoCAD DWG block".
I have made a DWG of this transmitter and then made a block and then added a port.
I have opened Spec editor > Create New Component > Custom - AutoCAD DWG Block based graphics > Number of connection ports "1" > select the DWG of the P. Transmitter.
So, the component is now added to the catalog, then I have also added the component to the spec "Instrument metric".
After opening Plant 3D, that P. Transmitter is not visible in the TOOL PALETTES under the tab "instrumentation spec".
I am using AutoCAD Plant 3D ver. 2024.
Please who can help me to make this?
Thanks in advance for all the responses.
Replies (13)
Message 2 of 14
h_eger
@fahmi_audishNMWLM
have you also updated the instrumentation.spec with your Plant 3D project?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 14
fahmi_audishNMWLM
Yes, I do this at every changes in the specs>
Message 4 of 14
fahmi_audishNMWLM
The thing is, I see "instrumentation Metric" in the Pipe specs (pic 1), but I can't select it in the box for "Route Pipe" (pic 2)
Message 5 of 14
h_eger
If you open your Instrumentation Metric Spec from your P3D project for editing in the Speceditor, is your new component also available?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 6 of 14
fahmi_audishNMWLM
Yes,
Message 7 of 14
h_eger
Can you check whether you can see your component in the Spec Viewer?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 14
fahmi_audishNMWLM
No, I can not see my component in the Spec Viewer
Message 9 of 14
h_eger
Then the component is not in your P3D Project Instrumentation Metric Spec.
As already written at the beginning!
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 14
fahmi_audishNMWLM
How can I solve this, do you perhaps have a method to properly include this component in the project?
Message 11 of 14
h_eger
Now a quick question:
How was your AutoCAD Plant 3D basic training?
Was this topic not covered?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 12 of 14
fahmi_audishNMWLM
Basic training, but I have now a good experience in making a pipe spec, onl dit topic not.
Message 13 of 14
h_eger
Open your Instrument Metric Pipe Spec in the Project Manager under the Pipe Spec folder with a right click and Edit Spec...
You can then add your component from your catalogue to your Instrument Metric Pipe Spec project and save it.
Then restart Plant 3D and it should work.
But now you know which areas of Plant 3D you should still train!
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 14 of 14
fahmi_audishNMWLM
Thank you very very much.
