Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Adding a BUILT IN GASKET VALVES
Message 1 of 11
HI everyone have anyone tries to add a built-in gaskets valves to the valve catalogue to connect directly to flange or stub-end and the gasket not added in BOM
i have tried to make the end type to be undefined_et but didn't work
Replies (10)
Message 2 of 11
fatherof3
Hey naberster
I can't find the link right now, there's a lot of previous discussions out there regarding this issue. If you search with keywords like "wafer valves no gasket" you should be able to find a solution, or maybe someone else will post it.
I can tell you its nothing to do with the catalogs, its all about setting up the right type of connections in the joint setup portion of the project setup.
Message 3 of 11
fatherof3
try this link:
http://www.screencast.com/t/zBVkR1N3yeC
It's a video, follow the steps, and it will do what you need.
It will not be a completely automatic thing. After you place the valve in the model, you will need to remember to substitute one of the connections. The video will explain it.
Message 4 of 11
TomislavGolubovic
Which version of Plant3D are you using??
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 5 of 11
Hi thanks for your fast reply i will check out the videos and my version of Plant 3D is 2016
Message 6 of 11
TomislavGolubovic
I'm sure one of the SP's or Extension 1 had something new like a flanged connection with bolts only and no gasket, but I can't find the readme for it.....
Tomislav Golubovic
Autodesk, Inc.
Message 7 of 11
Hi thanks for your reply but the video is not working i think there is somthing wrong in the site so if you have any other links of that video please send it to me.
Message 8 of 11
fatherof3
Message 9 of 11
fatherof3
Also, I should mention that in my original reply I said it has nothing to do with the Catalog setup. Well, really it does a little, since it will require the correct component end types be set in the catalog.
Message 10 of 11
yes thanks for your reply i have figured it out , i have to modify the end connection in the catalouge thanks for your reply and concen
Message 11 of 11
MOLGRAND
Hi, I have followed the web cast & although the solutions seems to work well - the down side i can see is the creation of dots for the  universal fastener connector - these can be seen on the web cast against the valve. As I am producing a weld list on my isos these now report as line size welds! is there any further way to remove this or creat a new fastener which doesnt report as a weld.
Im currently using 2016 & thought some of these work arounds would have now been incorporated within the package as a std by now, as was doing a simular fudge in 2012.
Gary Randall
