Access P&ID Class properties like Tag, class of a P&ID Object using lisp
ArunS2DHBM
ArunS2DHBM
I want to Access P&ID Class properties like Tag, class of a P&ID Object -instruments using lisp program. I aim to capture the Tag of the instrument and it should automatically update on the corresponding Instrument Loop Number.
I'm Unable to access the Tag of the equipment nor the instrument.
i have given a sample code for capturing the properties-"layer" of Equipment and changing the layer of the instrument. Similar manner i required to capture first the Tag of equipment and the it should update the Instrument Loop Number.
(defun c:UpdateInstrumentLayerFromEquipment ()
(setq equipmentObj (car (entsel "\nSelect the equipment: "))) ; Prompt the user to select the equipment
(if (not equipmentObj)
(progn
(alert "No equipment selected. Please select an equipment.")
(princ)
(setq equipmentLayer (cdr (assoc 8 (entget equipmentObj)))) ; Get the layer name of the selected equipment
(if (not equipmentLayer)
(progn
(alert "Layer name not found for the selected equipment.")
(princ)
(setq instrumentObj (car (entsel "\nSelect the instrument: "))) ; Prompt the user to select the instrument
(if (not instrumentObj)
(progn
(alert "No instrument selected. Please select an instrument.")
(princ)
(command "_.CHPROP" instrumentObj "" "la" equipmentLayer "") ; Change the layer property of the instrument to the equipment's layer
(alert (strcat "Layer of the instrument updated to: " equipmentLayer))
(princ)
h_eger
Dear @ArunS2DHBM ,
This does not work with Lisp!
You need the SDK for Plant 3D
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
ArunS2DHBM
Hi @h_eger
Can you please explain the method, or how use SDK. if possible, with the required codes for my need.
h_eger
@ArunS2DHBM ,
You can work that out for yourself or buy such a service in your area - I don't have the time for it
https://adndevblog.typepad.com/.services/blog/6a0167607c2431970b0162ffdc445e970d/search?filter.q=Pla...
Hartmut Eger
Senior Engineer
XING | LinkedIn
