We are currently using Autodesk Plant3D 2025 in combination with the Vault Professional 2025, and we want to be able to see the tag-assigned objects within the drawing on Vault DB UI. However, the lowest component accessible with Vault DB is the .dwg file. There is no other subcategory that can be visible. Is there a way so that we can get the information of the tag-assigned objects within the P&ID drawing from vault client?
Thanks.
