3DMOVE is misaligning
trlKQP4E
trlKQP4E
Why does the 3DMOVE not snap center-to-center but rather offset.
This goes for most of the components.
See snapshot of TEE failing to align w pipe by 29.425mm in Z-dir.
h_eger
@trlKQP4E ,
simply because 3DMOVE is not supported by Plant 3D
Pipeline components.
You should use the functionality of Plant 3D or was this not addressed in your Plant 3D training?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
trlKQP4E
sorry, could you enlighten me what functionality you refer to?
h_eger
https://help.autodesk.com/view/PLNT3D/2024/ENU/?guid=GUID-98538A5B-3C1D-4B26-8097-B2C1FE66CBF0
Hartmut Eger
Senior Engineer
XING | LinkedIn
