How are you supposed to navigate around your model if everytime you use the ORBIT command you are afraid the computer will crash?!?
I've turned off auto-target (or whatever it's called) per the recommendations, but with 95% of my crashes, the Orbit command is active in the command line.
I tend to get lost in the model when using wireframe modes so 90% of the time I would use Realistic, with the remainder being 2D Wireframe. I'll try switching to Shaded & Wireframe and see how it goes. I keep HW acceleration turned off most of the time as well. Video card is a Quadro 4000.
I believe this Orbit issue has been around for quite some time. I was reading a thread back in 2010-11 where someone was complaining about the crashes.
I just had a fatal error occur while the 3DORBIT command was active. The "auto-suggested" fix came up this time with the unchecking of the "Enable Orbit Auto Target" feature. I've done this in the past but the errors continued. I happend to check to see if the feature was turned on, and it was..! Is this a per drawing setting? I thought it was a global setting.
The 3D mouse doesnt use the same command. No one I know that uses this mouse has ever had a crash with it. It takes a little time to get used to but it's well worth while.
There's a new hotfix for AutoCAD that may help some of these crashes.
"Autodesk AutoCAD 2014 Zoom-Pan-Regen inside Viewport Hotfix"
I don't think it will help all of them, but it might reduce the number.
If you do crash, please send the crash report to us. We really do use this information to prioritize hotfixes.
This is an old time issue. For us, 2015 version is getting even more crashes than 2013 & 2014 versions. Of course always wireframe..
Hope you can fix it one day.
regards
AutoCAD Plant3D 2015
Main Board: ASUS RAMPAGE IV EXTREME
Intel(R) Core(TM) i7-4960X CPU @ 3.60GHz 3.60 GHz
RAM: 32,0 GB
Main System SSD - Gen3 SSHD Technology - Intel 510 Series
Windows 7 Professional 64 bits
NVIDIA Quadro K5000
