AutoCAD Plant 3D Forum
1 connection non catalog item in ISO sketch
6 REPLIES 6
popovUS9BY
280 Views, 6 Replies
Hello colleagues,
I have flanged spark arrestor in the end of Dn80 SS150 pipe.
Since there is no such a custom component i made it from 3D block.
In model everything is fine:
When ISO is created I got this:
Some huge dimensions and angle of displacement appear (component is just 110mm high, but some dimensions of hundreds are on ISO sketch).
I pay attention this is default situation for 1 connection custom components.
Any ideas hot to make component to appear normal in ISO sketch?
Regards
6 REPLIES 6
quan_hm
in reply to: popovUS9BY
Can you upload the drawing?
Hoang Minh Quan - Piping design engineer
Autodesk Store for Python Catalog
h_eger
@popovUS9BY ,
please ALWAYS create such components with 2 connection points.
Otherwise the iso with the alignment refers to the coordinate 0,0,0
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
popovUS9BY
in reply to: quan_hm
thanks for reply.
Both block and component are in attached archive. SS150 spec is used.
If you found a way please tell me.
I got a lot of 1 connection components like spark arresters, Strorz couplings with caps and other stuff I do not know even know how to write in English.
Regards
popovUS9BY
in reply to: h_eger
Hello H.Eger,
danke for reply.
to create 2 connections components leaving one not connected - right?
Regards
h_eger
Hello @popovUS9BY ,
exactly they need the 2nd connection point to ensure the orientation in the iso generation.
The 2nd connection point remains unused
Hartmut Eger
Senior Engineer
XING | LinkedIn
quan_hm
How about make it as flange-blind type so something like this: TYPE=FLANGE-BLIND,SKEY=FLSO
in isodefinition?
