Move object to UCS
Move object to UCS
mathieuJDL79
Move object to UCS
mathieuJDL79
Hi there,
Short long story, I missed my free trial to test the basics options I need to prepare DWG of my client for Solidworks (was looking for the wrong problem...).
I need to delete all object outside my selection (Ctrl + A | Select objects to keep | Delete) and move them to the UCS. It's basically the only things I need to do to have a working DWG in Solidworks.
Will I be able to move all selected objects to the UCS using this method?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-move-drawin...
Mathieu
pendean
Community Legend
Community Legend
You links are for PC (and MAC) based AutoCAD.
AutoCADWEB has limited abilities, look here
https://help.autodesk.com/view/ACADWEB/ENU/
mathieuJDL79
Thanks for you answer.
I know the link is for AutoCAD, that's why a post here to check if I can use this command with AutoCAD web.
The command Move exist, but it's not specified if I can use coordinates.
pendean
Community Legend
Community Legend
If you read your original links, and understand what the steps they want you to take take, you'll find most of the tips work  in ACADWEB starting at the MOVE command prompt. Where iT asks for #0,0 and #0,0,0, just use 0,0 and 0,0,0 instead (another reason to find the correct software HELP instead of 'similar software').
HTH
mathieuJDL79
Thanks, I just wanted to confirm it!
