Message 1 of 14
using autocad web application , how to create 3D object and use 3D comments
hello @rkarun_86
I agree with @pendean. Creating these objects is not possible in the AutoCAD Web Application. Commands like for example EXTRUDE or 3DORBIT are not implemented yet.
But when you create these objects in your AutoCAD Desktop Application, save the drawing in a certain view and upload the file to web.autocad.com, you will be able to see them:
Did one of the posts helped you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward
Best regards,
Thomas
A drawn out workaround would be to draw each shape, face-by-face, by changing the orientation of the drawing. Of course, this isn't sustainable and rotating shapes may have indeterminate behavior. But, if the purpose is purely for visualizing, this is one way to go about it.
is it still not available now? - on a trial atm deciding - if to buy
Nothing has changed since this original query was created.
Any changes?
No, you cannot draw 3D objects in AutoCAD web app. Similarly to AutoCAD LT, you can perform some limited 3D operations, like drawing a polyline or circle and assigning it a "height" to make it 3D, change UCS in 3D, or even create a 3D face. But you will need to use the LISP functions in AutoCAD web - so it is nothing for the faint hearted.
Vladimir Michl, www.arkance.world - www.cadforum.cz
Have you made it completely, I am thinking to post this on triopost.pro
hi currently facing the same issue, i am wanna to create it for (mxplyerapks.info), if someone knows pls help me in this
