Message 1 of 9
Is their any solution to make 3d object in autocad offline like autodesk web
Hello @rkarun_86
Could you specify your question a bit more? Maybe with an example?
Thomas
My team is currently work from home through their personal laptop We are unable to take our workstation from office due to country lock down. one of our technical support inform about auto desk web to use from home. But it is only for autocad . Our personal laptop is not having autocad or advance steel ,Revit , Inventor for creating 3D Model of our equipment. We want to explore any medium like autodesk web to make 3D object with out installing software in our system.
We tried to connect our workstation in office through any desk but it is not much speed.
Can you help on this
Hello @rkarun_86
How about using Autodesk Tinkercad to create your 3D objects in the browser. Of course you have to expect less functionality than you are used to.
Please clarify on your side the commercial usage.
You could export the model to an STL file and convert it afterwards to a DWG file. You can use your Inventor to convert a STL file to DWG.
Did the post helped you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Hello @rkarun_86
Could the information provided help you and answer your question? 🙂
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please don't hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
i need help making a 3d model in autocad
In AutoCAD or in AutoCAD on the web? If in AutoCAD, please ask in the AutoCAD forum.
Vladimir Michl, www.arkance.world - www.cadforum.cz
