How can I turn off lasso window selection?
martinEXSJV
Observer Observer
Message 1 of 13
martinEXSJV
Observer
Observer
I came back to my project and found out that I'm using some kind of lasso selection. It dost not longer draw rectangle for selection. The lasso thing makes me confused as I don't get how it selects the objects and I'd like to switch it off but have no clue how. It tells something about pressing spacebar when I click and hold but spacebar does nothing. Trying searching help and google and no luck
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Greetings @martinEXSJV
LASSO, by design, is triggered only when you hold down the mouse selection button for one whole second instead of just clicking and releasing. Is your mouse's button getting sticky and you need to replace it?
Or are you "behaving" differently for some reason (I catch my self doing it if I was on a different software that worked this different way).
Look up this in HELP is you wish to remove that option forever (if an option in the WEB version, I did not try it).
Message 3 of 13
pradacr
Observer
Observer
This problem happened to me  apparently when I changed the computer (from one chromebook to another).
I typed the command and put the 3 options, but nothing happened, I am trying to get used to the lasso selection now.
The rectangle is only visible for a small fraction of a second, very annoying :o(
Message 4 of 13
ivan_evans5N7UE
In AutoCAD Web and selection can only be made using lasso, I will be happy to help you resolve this issue.
The cause is this issue is due to the fact that the Selection Settings are se to Web Standard.
In order to fix this, follow the steps below:
  1. Click on the Settings Icon at the top right.
  2. Go to the Preferences tab > Selection Settings.
  3. Set it to Desktop Standard.
Message 5 of 13
pradacr
Observer
Observer
Solved, the option is on the settings icon on the files screen, thank you!!!
Message 6 of 13
dropdmessage
Observer
Observer
Please explain how it was solved. I have the same problem. thanks
Message 7 of 13
dropdmessage
Observer
Observer
Message 8 of 13
ivan_evans5N7UE
Message 9 of 13
dropdmessage
Observer
Observer
Done that but still the same.
Message 10 of 13
ivan_evans5N7UE
Reboot?
Message 11 of 13
dropdmessage
Observer
Observer
D=Reboot. Still the same
Message 12 of 13
ivan_evans5N7UE
Left click less than a second, do not click and hold, that will bring up lasso?
Message 13 of 13
dropdmessage
Observer
Observer
Thanks. This works
