Cloud Environment For Autocad
Is it possible to set up a cloud environment for auto cad where all the files, external references are stored in the cloud and Users will be able to open how they were doing from local computer or from a network drive.
Also would like to know the pros and cons, speed factor, offline availability.
Also which cloud provider is best in terms for Scalability, availability, security and all other factors.
pendean
Community Legend
Community Legend
AutoAd360 can be connected to Dropbox, Google Drive and OneDrive. Red more about it here http://help.autocad360.com/customer/en_us/portal/topics/502355-work-with-dropbox-one-drive-and-googl...
But this cloud app cannot work with your in-house server or PC directly.
mwn
If you are using AutoCAD installed on Windows then there is Autodesk Sync that will connect your desktop AutoCAD to A360.  You can also use other vendors such as Box, Dropbox, etc.  I would suggest doing a little research to figure out what would work best for you.
Hope this helps,
-mike
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
