Can you import a PDF into the AutoCAD web app?
I have tried typing in various commands into the command line, but nothing shows up under either pdf or txt. Is this action something that is not supported by the Web app?
mwn
Currently there is no ability to insert or attach a PDF into a DWG from AutoCAD web.
Best regards,
-mike
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
jimmy.wick90
AutoCAD supports creating PDF files as a publishing output for AutoCAD drawings, and importing PDF data into AutoCAD using either of two options: PDF files can be attached to drawings as underlays, which can be used as a reference when collaborating on projects.
J Wick
BaraaAlkhalaf
Hi @Anonymous
Welcome to AutoCAD Web App forum 🙂
Attaching PDF has not been supported.
Currently Xref attach only supports dwg and images.
Did the post helped you and answered your question?If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Kind regards,
Bara'a Alkhalaf
Global Technical Support
