I would like the ability to plot to PDF using only the layout name as the default file name.
Like many others, our file names must match the drawing number. Having to rename hundreds of files (thousands throughout the duration of a project) creates a lot of extra admin work that should not (ideally) be required.
Our base model is used for multiple drawings; it has a generic name set by others. If I could rename the base file, I could make the default name work by using the file name as the common prefix of the drawing and naming the layout with the number after the dash BUT - this only works as long as the drawing number prefix is the same for all documents published from the file and as long as the drawing number has a dash in it (AutoCAD always puts a dash in the file name). Different project have different standards so sometimes drawing numbers do not use a common prefix and sometimes they do not have a dash in them.
