Advance Steel Object Enabler
We are in need of a viewer that can pull actual dimensions (and include things like apparent intersections) for Advance Steel generated shop drawings.  Currently opening shop drawings generated from Advance Steel in Autocad Mobile just shows a blank sheet.  It needs the object enabler to display.
The Autodesk Online Viewer displays the items but the dimensioning abilities are lacking (not able to do apparent intersections or other more complicated dimension styles).
In a perfect world, if the object enabler were added it would be great to have Advance Steel dimension capabilities - basically the dimensions need to recognize what scale the Advance Steel objects were detailed at and scale accordingly.
