AutoCAD on mobile Forum
Welcome to Autodesk’s AutoCAD on mobile Forums. Share your knowledge, ask questions, and explore popular AutoCAD on mobile topics.
When I log in to the AutoCAD Mobile a white screen appears
2 REPLIES 2
harun.kaya9R8N3
962 Views, 2 Replies
I want to log in to the Autocad mobile program, but after entering the mail and password, a white screen appears in front of me at this stage.Can you help me?
@harun.kaya9R8N3 Topic Title has been changed for better findability by @joaquim.moral Original Post:
the problem of introduction to autocad mobile
2 REPLIES 2
Hi @harun.kaya9R8N3 :
Welcome to AutoCAD Mobile Forum:
Try the following steps:
  1. Open the general settings of the mobile device.
  2. Go to Apps > Default apps settings.
  3. Choose "Opening links".
  4. Switch on "Opening links in apps".
  5. Choose AutoCAD.
  6. Make sure "Open supported links" is switched on.
  7. Click on "Supported web addresses.
  8. Check if "login.mobilestg.autocad.com" and "login.mobile.autocad.com" are listed.
  9. If not add both web addresses.
  10. Try and login to AutoCAD Mobile again.
Did the post helped you and answered your question?If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward
Kind regards
Bara'a Alkhalaf
Global Technical Support
Hi @BaraaAlkhalaf,
thanks for your answer and your support in the forums.
Best,
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
