please help: i'm using Autocad Ultimate mobile, but i can't see the "smart pen" or "quick tool" on the software, please just help, Thanks!
Solved by Thomas_Stuehle. Go to Solution.
Solved by pendean. Go to Solution.
Hello @Anonymous
the smart pen function is only temporary not available on an iOs device when using Mobile App. Background information are described here: "AutoCAD mobile app updates". Unfortunately I do not have any influence on the timing of feedback.
Regarding your question - on an Android device the function is available. I just ran the same function here on my Android device:
The quick toolbar including the Smart Pen is directly available when you open a drawing and it works as expected: It creates an arc when I want to draw one.
Hope this helps.
@Anonymous Could the information provided help you and answer your question?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please dont hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
Thanks for the solution! I was also wondering why its not working on my iphone but its working on my friend's android phone. Its a good thing I found this thread because I was about to post the same problem.
Hej,
Någon klarhet i detta ärende? Kör en 30-dagars trial och AutoCAD mobile verkar i princip helt oanvändbart. Helt obegripligt hur man ritar enklaste linje med ett finger och ännu värre om jag försöker med smartpenna.
Finns ingen funktion som heter "Smart Pen" eller "Sketch".
Kör Autocad Mobile på en Surface Pro 8.
