I am getting an error when I try to enter negative coordinates on AutoCAD for iPad to draw lines. Is there a fix?
Solved by BaraaAlkhalaf. Go to Solution.
Hi @Anonymous 🙂
I would say that, you can enter a negative value for the Y axis and Z axis. The issue only with X axis
Will the bug on entering negative coordinates and autocad mobile be fixed?
