How to move an object without zero point
i would like to move an object. I’m using the move command. I select the object and select a corner of the closed polyline. The object moves over the drawing, but it somehow always moves from the zero point of the y and x reference lines. How do I disable or solve this? I’m working strictly on iPad.
I would like to upload a screenshot, but also not possible on iPad….
BaraaAlkhalaf
Hi @Anonymous 🙂
Thank you for your inquiry.
Using move command in AutoCAD or AutoCAD mobile requires defining a base point.  If you don't want to use the zero point just select a point from your object as base point and continue.
Regarding your question about uplading screenshot, you can use XERF command to attach an Image to your drawing.
Please select the Accept as Solution button if my post solves your issue or answers your question
Bara'a Alkhalaf
Global Technical Support
scottpmeissner
Observer
Observer
You can use external force action on your system that can be move as you want
