How to load an XREF to my drawing in AutoCAD Mobile?
cad.bimVX8B4
cad.bimVX8B4
Hello there
Can I load an XREF to my drawing? that help me to see the difference between them
thanks for your help
@cad.bimVX8B4
Topic Title has been changed for better findability by @joaquim.moral Original Post: XREF
Replies (7)
BaraaAlkhalaf
Hi @cad.bimVX8B4 🙂
Welcome to AutoCAD Mobile Forum.
To add image, dwg, or PDF file as Xref, kindly type Xref on the command line in AutoCAD Mobile app and then select the file that you want.
Did the post helped you and answered your question?If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Bara'a Alkhalaf
Global Technical Support
cad.bimVX8B4
Thanks for your support
jenniferAJPHQ
Observer
Observer
When I look for the .pdf files they are not shown in the folder. Can I not attached pdf files as xrefs? The only file shown are images, jpeg etc
Thanks!
jenniferAJPHQ
Observer
Observer
When I try to load my xref's  in the mobile app that are PDF's they are not shown in the folder. The only options are jpeg or other image files. Can I not use PDF files as xrefs?
Thanks!
wimag_arq
The Autocad Mobile doesn t load refx files working in Drobox. We placed all files in de same folder. We maded absolut xref files. Always appear in xref bottom a red ! Into a yelow triangle, and it isn t work at touch mode in the tablet. What can we do?
shahaast555
Community Visitor
Community Visitor
To load an XREF into your drawing in AutoCAD Mobile, please follow the below steps:
  1. Open your drawing in AutoCAD Mobile.
  2. Tap on the "Insert" icon on the bottom menu.
  3. Select "XREF" from the insert options.
  4. Choose the location of your XREF file from the options provided.
  5. Select the XREF file you want to load and tap on "Open".
  6. You will be prompted to specify the insertion point for the XREF. Choose the desired location and tap on "OK".
  7. The XREF will be loaded into your drawing.
  8. You can then use the "XREF" command to manage the properties of the XREF, such as its visibility, layer properties, and insertion point.
Note: The steps to load an XREF in AutoCAD Mobile may vary slightly depending on the version of the software you are using....Read More
marian_bunea
Community Visitor
Community Visitor
Your answer is not related with the problem. The drawing have the xref's attached, can be seen on desktop but when you try to open from Mobile, no xref
