Are there any plans to support other laser measure devices such as the Bosch GLM series? Trying to decide if I should by the Leica Disto or wait to see if Bosch devices get added.
Solved by Thomas_Stuehle. Go to Solution.
Solved by pendean. Go to Solution.
Thanks for contacting us,
So far there's no plan to support other laser measure device.
Macro
Can Bosch now be linked. Also, my win 10 version of mobile app on my 2 in 1 does not even have a feature for distance finder link. why is that. Please link ASAP. as 2 in 1 laptops are better for site work. Perhaps Autocad itself can utilise distance finders.
Hello Wayne @wayneB52SL
Could the information provided by @pendean help you and answer your question?
Based on the post above, let me add the information (even though it is a different topic), that you can link / connect to some things from the webbrowser:
But for hardware like the Bosch GLM it is true.
Based on this fact, a topic already exists in the AutoCAD Mobile Ideas section: Bosch GML Support. I can only encourage you to vote for this idea to influence future decisions about this topic.
If you wish this feature to be improved in the future, Please also provide feedback at feedback.pro@autocadmobile.com.
Could the information help you and answer your question even though it was not a solution for your situation?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please dont hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
Autodesk really needs to put some effort into the mobile app as it really sucks, I have used other apps that are much better- try Arcsite, as it actually draws walls you don’t need to offset the lines, and it works with Bosch and Leica laser measurer.
The idea has been there since 2018. It’s like this has been ignored. You can easily find the Bosch app kit and implement it in your autocad app. Magicplan, ArcSite , and other apps already have this support but not Autocad ?
Sadly, it means nothing to point that out in this exact forum. Sorry.
and 1 or few reports/requests back in 2018 has little to no impact as opposed 1000s of requests often and every year. That's just a reality. How badly do you really want it?
Note: if you need the abilities of the other apps today, then you need to do what is best for you. Autodesk's CEO says they expect all of us to do so.
Good luck.
