Everytime I try to attach a jpeg image from my iPad to my AutoCAD file the app shuts down when asked to specify the scale factor of the image.
Solved by Willjoe2442. Go to Solution.
Hi @Aldo.Rooze
Welcome on AutoCAD mobile forum 🙂
I could attach an image using my AutoCAD Mobile version 6.0.1 ios System.
Is it possible to share with me your drawing and the image to test the command on my system?
Kind regards,
To Add Images Using Insert Image
Click Home tab Data panel Insert An Image.
In the Insert Image dialog box, select the drive and folder that contains the image(s).
In the Files Of Type box, select the file format of the image(s) to insert.
In the list of images, select the images to insert.
Will
