A360 Translates half drawing different;y
jeffHGCE
Message 1 of 8
jeffHGCE
Has anyone had problems with A360 showing half the objects in area of the drawing and the other half in another, and some are randomly in different places.
It looks like if you selected half the objects and then just moved and rotated them far away.
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
One file or ALL files?
Is this in paperspace? It happens sometimes, it's like viewports 'bleed' and skip around on mobile devices. Should not happen in modelspace (or at least I've not seen it) and I haven't seen it happen in the webbrowser version.
Only fix that works most of the time is to delete the file and re-upload it to the AutoCAD360 drive: sometimes you have to recreate the layout in AutoCAD first.
Message 3 of 8
jeffHGCE
Thanks for the reply.
It is the first floor plan i tried.
All objects are in model space and it is a large building something like million square feet.
Message 4 of 8
jeffHGCE
Its has more than one saved UCS in it the file, not sure why but looks like that half of the objects are translated by that? I just started messing with it and have not looked at point values to see if that was the case.
Message 5 of 8
pendean
Community Legend
Community Legend
Is the distorted view only in paperspace, in a layout?
or is it actually in modelspace?
Regardless of where you content is placed 🙂
Which UCS is active?
There is no 'translation": unless you are uploading a format other than dwg of course.
Message 6 of 8
jeffHGCE
EVERYTHING is in model space.
In mathematics, translation refers to moving an object without changing it in any other way.
I tried adding a viewport in paperspace to see if that would work but now the drawing will not open A360.
This is quickly not becoming worth it and back to marking up on paper in the field.
Message 7 of 8
pendean
Community Legend
Community Legend
If there is a chance, I'd love to see the actual DWG file to test it.
Message 8 of 8
tirza.ben-ner
Hi @jeffHGCE,
We'd be happy to examine your file. Feel free to contact us directly at [email protected], with the file attached and we'll take it from there.
Tirza Ben-Ner
AutoCAD 360 Support Specialist
