Xattach File Corruption
ewfranklin607
Message 1 of 15
ewfranklin607
Can anyone tell me hoe to replace the file that xattach runs. I get an error message when I try to run the command. I have done a repair and it didn't help. I don't want to do a complete reinstall unless that is the only option.
Replies (14)
Message 2 of 15
ewfranklin607
The version is 2012 MEP
Message 3 of 15
Do you get the same error message when using the dialogue box "XR" command?
Message 4 of 15
ewfranklin607
Yes. I get it anytime I try to run xattach from the command line or the dialogue box.
Message 5 of 15
Holger.Kloecker
Autodesk Support
Autodesk Support
Can you let me know what the exact wording of the error message is you are receiving?
If appropriate you might attach a screenshot.
Thanks!
Holger Klöcker
Message 6 of 15
ewfranklin607
This is the message that comes up when I try to run the file. I don't get the screen that allows choices of the xref. This error comes up instantly. See Attachment
Message 7 of 15
Holger.Kloecker
Autodesk Support
Autodesk Support
Okay, it looks like AutoCAD has still some invalid file in cache that it tries to access when you run the XATTACH command. Let's try the following:
Type FILEDIA and set it to 0
Run the XATTACH command again. You will be prompted on the command line for the filepath to the DWG to attach.
Enter something like:
c:\Test\Drawing.dwg
Does this let you attach the file in question?
Can you run the XATTACH command again properly after changing FILEDIA back to 1?
Holger Klöcker
Message 8 of 15
ewfranklin607
FILEDIA was already set to 1. I still have the same error.
Message 9 of 15
Holger.Kloecker
Autodesk Support
Autodesk Support
c:\Test\Drawing.dwg
Holger Klöcker
Message 10 of 15
ewfranklin607
I apologize for misreading the previous message. I set to 0 and I could attach with the command line but not the dialogue box. Also with FILEDIA set to zero I cannot open drawings except with the command line. No doalogue box appears.
Message 11 of 15
ewfranklin607
When I change it back to 1 I still get the same error message.
Message 12 of 15
Holger.Kloecker
Autodesk Support
Autodesk Support
The only other option to check - apart from performing a reinstall - is to test with another user account.
Can you setup a new user account on the machine just for testing purposes (use local admin permission) and check if the issue is also occuring when starting MEP in this new profile?
It it does, it is likely that this is caused by some user profile corruption and we can try resetting the profile you are normally using.
If if also occurs in the new profile, I am afraid the next best option is to try and perform a reinstall.
Holger Klöcker
Message 13 of 15
ewfranklin607
I think I am just going to do a complete reinstall sometime this week. Thanks for your help.
Message 14 of 15
Holger.Kloecker
Autodesk Support
Autodesk Support
OK, that makes sense.
When performing the uninstall, you might want to follow the instructions given here:
http://usa.autodesk.com/getdoc/id=TS45252
This will ensure a clean uninstallation of AutoCAD MEP.
Holger Klöcker
Message 15 of 15
ewfranklin607
