I'm trying to adjust the break distance when (2) single line pipes are crossing each other. The default setting shows up alright in model space, but once I plot the drawings, you can't even tell there is a break. I've spent a couple hours looking through the system definitions, display properties, etc. to no avail.
Does anyone know if you can adjust this distance? I know how to adjust it with wire, but haven't found away to adjust it for pipe.
Any help is appreciated, thanks.
I attached a pic of what I'm describing.
It would be better if you supplied your answer so anyone else doing a search for this thread will know what the answer was!
