Object Snap Tracking Not Working
Ksustaire
Message 1 of 20
Ksustaire
I'm using AutoCAD MEP 2017 on Windows 10 Pro. I'm trying to use object snap with snap tracking and ortho to align some tags. It worked previously where I could grab a grip and hover over a point that I wanted to align to and a dotted line would appear and I could click and my grip would be lined up with that point. That still works in some files but recently I made a bunch of sheet files and this function won't work in them. I have attached a video showing how it won't work. I've tried to compare various system variables but I can't find the difference between these files. I'd appreciate any help.
Replies (19)
Message 2 of 20
pendean
Community Legend
Community Legend
rotated UCS by chance?
Is INT osnap running?
Message 3 of 20
Ksustaire
No, the UCS isn't rotated. I'm using WCS right now and I don't have the INT (intersection?) osnap on.
Message 4 of 20
Tiana_Y
Hi @Ksustaire
What is your OSNAPCOORD system variable set to?
Tiana.D
Community Program Manager
Contact Autodesk Support
Message 5 of 20
Ksustaire
My OSNAPCOORD is set to 2.
Message 6 of 20
pendean
Community Legend
Community Legend
INT should help, try it: what other running osnaps do you have on?
Message 7 of 20
Ksustaire
By INT do you mean the intersection snap?
Message 8 of 20
Tiana_Y
Hi @Ksustaire
If you change your OSNAPCOORD system variable to 1 does that seem to help at all?
Tiana.D
Message 9 of 20
Tiana_Y
Hi @Ksustaire
I'm just checking in to see if you need more help with this. Did the suggestion that @pendean or myself provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Message 10 of 20
Ksustaire
@Tiana_Y, your suggestion to change OSNAPCOORD to 1 may have helped. I've been trying out polar instead of ortho and now it only doesn't work sometimes. I think it's something with my computer or settings because I opened the same file on a coworker's computer and it worked fine. Guess I'll leave it there and limp along until I get a new computer.
Message 11 of 20
heather_o
I know this is probably silly...But I came across this:
This should apply to AutoCAD 2015 but you may want to try this if you are using another version with similar issues. When you use the Object Snap Tracking function it does not respect the Tracking Mark offset. You move the cursor over (as an example) an End Point and generate the Track Mark. Then you move away in (as an example) a horizontal direction. You type in a distance and enter and it does not track away from the marked point it ends up in an odd location.
How to Correct the issue:
This is a known issue that is being caused by the command line not being docked. Dock the command line and try again this should resolve the issue.
Message 12 of 20
Go to Object snap settings > Options. Then see if "Marker", "Magnet" and "Display Autosnap tooltip" box are checked.
Check the attached picture for reference.
Message 13 of 20
alangroberts
Thanks for your reply. I had forgotten about this issue and it suddenly started when it had been working perfectly for months on my current project. I had undocked my command line and re-docking it fixed it immediately. I really appreciate your input.
Message 14 of 20
bferguson
Thank You!  osnapcoord=1 fixed the problem I have been having for a month!  Nobody had a fix all over the internet.
Message 15 of 20
Just something I noticed whilst having same issue. I had "Shift to Acquire" selected on alignment point acquisition causing similar problem (unless using shift to lock tracking target)
options>drafting>alignment point acquisition
Message 16 of 20
Colin-Pearson
@Anonymous  THANK YOU!!!  I got a new laptop about 3-4 months ago and it had newer ACAD on it.  I've gotten most of the kinks of switching over worked out but that one was driving me crazy.  Have a good one!
Message 17 of 20
siennaFUWA3
Community Visitor
Community Visitor
UGH THIS FIXED IT FINALLY
Message 18 of 20
gustavoPVXHG
Observer
Observer
Message 19 of 20
designN2EJF
This fixed my issue. I guess I must have accidentally hit F11!
Message 20 of 20
duncanpageVY7U3
New Member
New Member
If you are having the same issue i was, then go to options (OP) and go to the drafting tab. From there make sure your "Alignment Point Acquisition" is set to Automatic. Took me a while and several forums to figure out why it was trying to track from my previous end point instead of the snap point i was currently on.
