missing 2D Section Shrinkwrap in 2d section when section line is not straight
g-eaux
g-eaux
I've a problem with missing  2D Section Shrinkwrap in 2d section when section line is not a single linear one.
the Shrinkwrap turn on or off at every new segment of the 2d section line.
you will see this problem for walls and slab in the page 2 of the pdf,
and here is the dwg :
sample.dwg
thanks for your help,
Gérald
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi g-eaux,
This issue has been reported by other users as well and is registered by Autodesk´s Product Design and Development Team.
In order to overcome this issue, there is a program code change necessary.
As a workaround for such sections in the current versions of AutoCAD Architecture and AutoCAD MEP, you will need to adjust the linework of the affected sections manually. Please, follow this procedure to do so:
To Edit Linework in a 2D Section
I understand you were hoping for some better news, but I hope, that you´ll find this information still valuable.
This issue is not considered as resolved by Autodesk as long as we haven´t been able to implement an according program code change, however,
In order to point other customers with the same question to the current status of this issue, I´ll go ahead and mark this reply of mine as an accepted solution.
Thanks for your patience and understanding and also thank you for your participation in the forum.
Best regards,
Zsolt Varga
Technical Support Specialist
Revit Ideas | Screencast | Revit Help | AKN
g-eaux
thanks for the reply,
it is quite a solution because:
- the changes made are kept even if you regen the 2dsection
- but it is very slow !
waiting for the code modification ...
Gérald
