MEP Snap issue - Can't temporarily turn them off.
mdhutchinson
Advisor Advisor
mdhutchinson
This is AutoCAD MEP 2013...
I am having issues with MEP snaps. I cannot model a pipe run that is anywhere close to an existing run. If I do it wants to connect to the neighboring run but cannot find the necessary fitting and so it prompts for a part. I don't want to connect to another run. I can do Cntl-F3 to temporarily disable MEP snaps, but it still does this. I have even turned off the MEP snaps (and AutoCAD Snaps) but it still misbehaves.
The only way it will behave is if I delete the neighboring run, finish the new run, then do 'oops' to restore the neighboring run.
Is there something I am missing?
Keith.Brown
If you CTRL-Click when placing your pipe run it will ignore all other entities and just place the pipe.
mdhutchinson
Thanks!
Is this one documented?
Shouldn't turning the snaps off, or doing Ctrl+F3 work?
Keith.Brown
I do not remeber where I read it but I do believe it is in the documentation somewhere.
I believe that mep will try to always connect objects even if the snaps are off.  The snaps just make it easier.  This is probably why there is a CTRL-CLICK option.
