MEP 2025 - Rectangular Elbow Showing Incorrectly
tony_csogroup
Message 1 of 16
tony_csogroup
Tried to draw a 400x400 rectangular duct with a DW144 flanghed square eblow, but the connection is drawn on the wrong side. Anyone else seeing this?
There is no connection on the other side.
Ive seen this problem in a prevouse verion, but with shoe branches.
Anthony Russell
LinkedIn
Replies (15)
Message 2 of 16
tony_csogroup
MEP Design view, showing connector in the wrong place.
Anthony Russell
LinkedIn
Message 3 of 16
tony_csogroup
Support have confirm that they can replicate the issue and will advise the devopment team. Should be fix in a future patch.
Back to the 2024 version I go...
Anthony Russell
LinkedIn
Message 4 of 16
yanhan.lim
Hi @tony_csogroup ,
Thank you for raising this issue. We apologies for the difficulty you have faced with the duct elbow in MEP 2025.
The development team has been able to reproduce this problem and have proceeded to log this
Best regards,
Yanhan
Yanhan Lim
QA Analyst
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Message 5 of 16
tony_csogroup
Nearly six months later... Just had to reinstall AutoCAD and accidently installed the 2025 version.
And... It's still not fixed.
Anthony Russell
LinkedIn
Message 6 of 16
tony_csogroup
AutoCAD MEP 2025 update 0.2 has just come out and this issue has not been fixed. This is almost a year later!
Can anyone tell me if this has been fixed in the 2026 version?
Anthony Russell
LinkedIn
Message 7 of 16
tony_csogroup
Just tried the 2026 version and it's still there. 🙄
Anthony Russell
LinkedIn
Message 8 of 16
yanhan.lim
Hi @tony_csogroup ,
Thanks for your follow-up on this thread issue. That is rather peculiar as this should be working as of MEP 2026.
I have went to take a look on my end and the part does look to be functioning as expected. Here is a screencast and photo of what it looks at my end.
Screen Recording - DW144 Duct Fitting
Would you be able to help answer a few questions:
  • Could you showcase what you are seeing on your end?
  • What MEP 2026 profile are you running?
Best regards,
Yanhan
Yanhan Lim
QA Analyst
Message 9 of 16
tony_csogroup
Hi @yanhan.lim
It seems to have been resolved in the 'Global' profile, but not the 'UK' profile. I have raised a ticket and it has been confirmed as such.
I'm now hoping that the fix will be in the first MEP 2026 update.
Anthony Russell
LinkedIn
Message 10 of 16
Sridhar-Autodesk
Hi @tony_csogroup
The shape of the DW144 Rectangular Duct Square Elbow Flanged_UKM part looks different in UK profile as compared to Global.  This snapshot is from MEP 2024 UK profile. Please see image below.
Do you expect to see same shape in MEP 2026 in UK profile as in the attached image or both UK and global profile should match?
Please let us know.
Best Regards,
Sridhar Subramani
Senior Product Owner
Message 11 of 16
CGBenner
@tony_csogroup
Hi, do you still need help with this question?
Chris Benner
Message 12 of 16
tony_csogroup
No thank you. Support confirmed the bug had not been fixed in the UK profile and should be fixed in a future patch.
Anthony Russell
LinkedIn
Message 13 of 16
tony_csogroup
The bug is not present in the 2024 version. I first noticed it in the 2025 version, but it was only fixed in the global profile and not the UK profile. The 2026 version inherited the bug.
Support have confirmed this to be so and have promised it would be corrected in a future patch.
Anthony Russell
LinkedIn
Message 14 of 16
Sridhar-Autodesk
Hi @tony_csogroup
Thank you for the reply.  I am from the product team.
The shape of this part is different in UK and Global profile.  I would like to confirm with you the shape of this part in UK profile is as shown in the attached image in my previous reply?
Thanks again for patience while we address this issue.
Best Regards,
Sridhar Subramani
Message 15 of 16
tony_csogroup
The shape of this part in the UK profile in the 2025 and 2026 versions do not look like this. It looks like this, which is not correct.
Anthony Russell
LinkedIn
Message 16 of 16
Sridhar-Autodesk
Hi @tony_csogroup
I have a fix for this issue and would like to send the drawing to you for verification.  Could you please drop me an email at [email protected]
Best,
Sridhar
Sridhar Subramani
