MEP 2018 object enabler for 2017 objects
Is there an object enabler?
I'm running MEP 2018.  I'm opening a 2017 File and the objects are not correct?
Is there an enabler that will work for me so I can see the content of the 2017 drawing?
Sridhar-Autodesk
@Anonymous
I assume when you say opening a 2017 file is MEP 2017 file?  If yes, we don't need an Object enabler to view MEP 2017 files in MEP 2018
Can you please attach a  2017sample drawing and highlight which objects are not when opened in 2018?
Sridhar Subramani
Senior Product Owner
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community and thank you for posting your question here in the AutoCAD MEP forum!
I'm just checking in to see if you'll be able to post a sample file and/or screenshot of the issue, as @Sridhar-Autodesk requested. Do you still need help with this?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
