Is there a way to explode AutoCad MEP Objects into AutoCad without them changing to multiple lines.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have received a drawing where all objects are 3D (an AutoCad MEP Drawing) which I need to convert into 2D objects so we can edit the drawing easier in normal AutoCad.
However there seems to be no easy way of doing this. I have enablers active so I can see the drawing, however using explode on these turns them into alot of lines and/or objects which still cant be edited.
I have tried to use the Flatshot, Flatten, and exporttoautocad commands but none of these have the desired effect or simply do not do anything. Is there any way to just turn them into simple 2D drawings without turning them into multiple objects?
The closest command I have got to work is using the flatten command and saying Yes to removing hidden lines, however this command works oddly depending on how far zoomed out you are and it would take too long to use this command whilst zoomed in enough to make it turn the objects into somewhat usable lines.
Surely there must be a way?
Thankyou.
