Extending Neighboring Conduit in Custom Schedules
Message 1 of 13
Is it possible to, when creating custom tables in MEP 2014, create subtotals by diameter that include both conduit length and length extended by neighboring fittings?
Replies (12)
Message 2 of 13
pothied
You can certainly create schedules that show conduit length and sort that with sub-totals by diameter but there is no way to add in the length of the fittings on the ends of the conduit. It might be possible with custom programing but I don't think that it would be easy and I don't think that the fitting "knows" it's length either. There is no length property of the fitting.
David Pothier
Message 3 of 13
VitalyF
This is an example grouping of pipes and fittings by size
This formula adds the length and quantity of all !!!! the pipes and fittings in this file.
Set app = GetObject (,"AutoCAD.Application")
On Error Resume Next
RESULT = "--"
Set baseApp = app.GetInterfaceObject("AecX.AecArchBaseApplication.7.5")
Set ActiveDoc =baseApp.ActiveDocument
Set ObjectCollection = ActiveDoc.ModelSpace
totLength = 0
n = "[PipeFittingObjects:PartSizeName]"
f = "[PipeFittingObjects:ObjectType]"
s = "[PipeFittingObjects:System]"
q = "[QUANTITY]"
For Each Object In ObjectCollection
	If Object.ObjectName = "AecbDbPipe" Then
		If Object.SizeName = n Then
			Ps = Object.SystemName
			Ps = Split(Ps," (",-1,1)(0)
			If StrComp(Ps, s, 1) = 0 Then
					totLength = totLength + Object.Length
			End If
		End if
	End If
Next
If f = "Pipe" Then RESULT = Replace( Round((totLength)/1000,2), ",", ",") End If
If f = "Pipe Fitting" Then RESULT = q End If
Message 4 of 13
VitalyF
This is an example Schedule Table grouping of conduit with conduit fitting by diametr for AMEP2014 ENU
For Conduit Global catalog
This is the formula for calculating the length of the conduit and fittings for AMEP2014 ENU
This formula is designed for routing with - "Fixed radius" from catalog only!
see formula -
radii = Array(52, 65, 78, 104, 130, 162.5, 208, 320, 505, 631.5)
RESULT = "--"
Set sched = app.GetInterfaceObject("AecX.AecScheduleApplication.7.5")
Set ActiveDoc = baseApp.ActiveDocument
totLength = 0
d = Cint("[PartSize]")
pi = 3.1416
	Set obj = Object
	If obj.ObjectName = "AecbDbConduit" Then
		If obj.Type = "Conduit" Then
			If CInt(Left(obj.SizeName, 2)) = d Then
				totLength = totLength + obj.Length
			End If
		End If
	End If
	If obj.ObjectName = "AecbDbConduitFitting" Then
			diameters = Array(8, 10, 12, 16, 20, 25, 32, 40, 50, 63)
			i = 0
			If (InStr(obj.SizeName, "Bent") > 0) Then
				i = 1
			ElseIf (InStr(obj.SizeName, "EMT") > 0) Then
				i = 2
			End If
			j = 0
			While (j <= UBound(diameters) and diameters(j) <> d)
				j = j + 1
			Wend
			Dim ns(3)
			'not Bent, not EMT
			ns(0) = Array(55, 55, 55, 55, 70, 75, 85, 85, 100, 120)
			'Bent
			ns(1) = Array(25, 25, 25, 25, 30, 30, 40, 40, 50, 60)
			'EMT
			ns(2) = Array(0, 50, 50, 50, 50, 50, 70, 80, 110, 135)
			alpha = 0
			Set propSets = sched.PropertySets(obj)
			For Each propSet In propSets
				For Each prop In propSet.properties
					If prop.Name = "PathAngle" Then
						alpha = CInt(prop.Value)
					End If
				Next
			Next
			L = ns(i)(j) * 2 + pi * radii(j) * alpha / 180
			totLength = totLength + L
		End If
	End If
Next
RESULT = Replace( Round((totLength)/1000,3), ",", ",")
 You can also modify the formula to group conduits by style, system, or(and) name!
Example with dwg file for AMEP 2014 ENU
Message 5 of 13
mdhutchinson
Thanks you soo... much for sharing this...
I had a bit of trouble tweaking a version of your schedule.
We have our Standard Property Data Format set to UPPER case (out of the box, AutoCAD MEP - the Upper is the default) ... your code compairs the SizeName and SystemName to total length and fitting quantites. With UPPER case I couldn't get your schedule to total up. I tried using UCase() vbs function a couple different ways... but couldn't stumble on to the right combination.
I am just a bit concered with change our Standard Property Data Format case to 'As Is' ... as we use it in a couple other places.
I wonder if you might offer a suggestion.
Message 6 of 13
VitalyF
mdhutchinson wrote:
I had a bit of trouble tweaking a version of your schedule...
Type command AEСVERSION and select the first two digits
Message 7 of 13
jtm2020hyo
how can I use your code?
Message 8 of 13
VitalyF
what are your problems with the formula?
just insert it into Schedule Table style, download example - ConduitLengthByDiametr.zip above
Message 9 of 13
jtm2020hyo
nothing, I am just new in MEP, I want to learn. The code looks like I need to install Visual Studio before use it. Can you upload any video doing this table?
Message 10 of 13
faugustom
Hy All!
I'm trying to group walls and get total lengths based on styles and height.
Using this code I can get the total by styles, but not by height
Could you help me find where is the error?
thank's
Message 11 of 13
seanmV8WWH
I have inserted your table style using AutoCad MEP 2022 and it does not work for "standard" conduit objects.
I cannot believe Autocad hasn't made a continuous conduit length with bends a default output in a schedule.
Message 12 of 13
faugustom
Hi!
There is any way to include objects in xref's?
Thank's
Message 13 of 13
surohbychandni
Community Visitor
Community Visitor
I'm trying to group walls and get total lengths based on styles and height for the store major environment checking but the AutoCAD file version not supporting at that time for the particular website and sheet is changing at the time of creating panel.
