Export and Import Settings missing in autoCAD MEP 2023
rraycmi
rraycmi
Does anyone know if the export and import settings is still a feature in 2023 like previous versions?   Example,  In previous versions I could select the windows button, path to 2022 autoCAD MEP and it would list options including an Export and Import Settings button.
Thanks in advance.
pendean
Community Legend
Community Legend
joaquim.moral
Hi @rraycmi,
Thank you for posting in the AutoCAD Forum! I'm checking in to see if you need more help with this. Did the suggestion that @pendean provided help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily. If not, let us know if you have any more questions so we can help you.
Best,
Joaquim
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
rraycmi
hmmm I must be missing part of the install.  I do not have the export/import on my drop down.
pendean
Community Legend
Community Legend
A repair/reinstall may be in order if a PC restart does not help: I suspect you'll have to find the hidden list on what to install and ensure they are selected. Is your OS login of the milted user account? Or are you a local/full admin on it?
rraycmi
User is admin.  I'm thinking the same thing about reinstalling with a new download.  I have to play around with the options to see what exactly give us export/import settings.  I'm also missing restore settings.
Thanks for your help.
rraycmi
Ok, i just figured it out. I created a deployment that was several autodesk programs. In the customization options there was a box to download " migrate custom settings." I had that box unchecked. Just ran a deployment on a machine and the settings are now there. Thanks.
